JHill1
6 years agoHow to set Java heap size for build scripts using "set_global_assignment -name QSYS_FILE"
If the project specifies a QSYS file using "set_global_assignment -name QSYS_FILE" then the quartus build will automatically synthesize the .qsys file. With this mechanism quartus is implicitly calli...
JHill1
6 years agoTo answer my own question...
export _JAVA_OPTIONS="-Xmx1g"
This works within bash or also within the GNU make file environment. On windows the set command can be used in a DOS environment.
