JHill1
6 years agoHow to set Java heap size for build scripts using "set_global_assignment -name QSYS_FILE"
If the project specifies a QSYS file using "set_global_assignment -name QSYS_FILE" then the quartus build will automatically synthesize the .qsys file. With this mechanism quartus is implicitly calli...
RichardT_altera
6 years agoIs the build fail due to OutOfMemoryError? I currently do not know how to set java heap size through the qsf file.
Perhaps this KDB could be an alternate solution for your case.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11152012_160.html
