12 years agoHi,
first you need to understand what are the inputs and outputs that the board has and what are the inputs and outputs the algorithm module has. From a quick look, the algorithm module takes a clock, a start and done signal and a 64x64 bit memory input interface and a 64x64 bit memory output interface. Of course, there's nothing on the board that can actually interface with this directly. So, you'll need to create a VHDL module where you instantiate the algorithm module, along with some kind of interface to the board's hardware. One quick way you can get it working in simulation: Create a module when you instantiate the algorithm module plus 2 64x64 altsyncsram modules (from the MegaWizard). One of the memory modules will be your input, the other the output. Create and set a .hex file on the input memory block with some data. Then give the design a "start" pulse and see that it writes the output on the output memory block. Once you have this working on simulation, you can make it work on hardware. - Assign the clock, reset, start and done signals. - Enable the In-System memory editor, this will allow you to write and read the contents of the memory blocks through the JTAG interface.
