19 years agoI'm not aware of any direct way to reserve an individual LUT or register location within a LAB.
If you are wanting a LAB to have certain nodes in it and want to reserve individual locations within the LAB just to keep everything else out, then could you put the nodes you do want there in a LogicLock region with "Reserve unused logic cells" enabled in the region properties? If you have some other reason for reserving an individual location, a description of the reason might make someone think of other suggestions.
