Altera_ForumHonored Contributor16 years agoHow to remove timing check of synchronizer? I used synchronizer chain to pass signal from different clock domain. When I run a timing simulation, the synchronizers generate X status because of setup and hold violations. Then I realized setu...Show More
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
