14 years agoHow to read USERCODE from FPGA?
How to read USERCODE from configured FPGA? I tried to use Quartus Programmer, but there is no function, which read and display the USERCODE from running FPGA. It surprise me, that Quartus Progra...
14 years ago --- Quote Start --- How to read USERCODE from configured FPGA? --- Quote End --- Using quartus_stp, you can issue JTAG commands to get this info, i.e.,
# -----------------------------------------------------------------# JTAG access (open/close)# -----------------------------------------------------------------
# Open the DE2 Cyclone II device using the on-board USB-Blaster.
proc jtag_open {} {
# Get the list of JTAG controllers
set hardware_names
# Select the first JTAG controller
set hardware_name
# Get the list of FPGAs in the JTAG chain
set device_names
# Select the first FPGA
set device_name
puts "\nJTAG: $hardware_name, FPGA: $device_name"
open_device -hardware_name $hardware_name
-device_name $device_name
# Close the device
proc jtag_close {} {
close_device
# -----------------------------------------------------------------# JTAG instructions# -----------------------------------------------------------------
# Read the JTAG ID code# * Expected ID code = 0x020B40DD#
proc read_idcode {} {
device_lock -timeout 10000
# Shift-IR: = IDCODE = 6
device_ir_shift -ir_value 6 -no_captured_ir_value
# Shift-DR: read 32-bits
set val 0x
device_unlock
return $val
# Read the JTAG USERCODE code# * If its not set, then the expected value is 0xFFFFFFFF# * The USERCODE can be set using, eg.# set_global_assignment -name STRATIX_JTAG_USER_CODE 12345678#
proc read_usercode {} {
# Shift-IR: = USERCODE = 7
device_ir_shift -ir_value 7 -no_captured_ir_value
set val 0x
device_unlock
return $val
Put the above in a file, save as say jtag.tcl, and then in quartus_stp type
source jtag.tcl
jtag_open
read_idcode
read_usercode
jtag_close
Easy, eh! Cheers, Dave
