11 years ago
how to read data from inout port into a testbench
Hi, I'm writing a test bench to write data into an sram module. I have to write the data and read back from it. data is inout port in that module. How do I read the data back from the module into my test bench? This is my code...
`timescale 1 ns/10 ps
module ht6116_tb();
reg [7:0] data_set;
wire [7:0] data;
reg [10:0] address;
reg write_enable_n, read_enable_n, chip_select_n, reset;
IDT6116SA15 M1(.IO(data), .A(address), .WE_N(write_enable_n), .OE_N(read_enable_n), .CS_N(chip_select_n), .RESET(reset));
assign data = data_set;
initial
begin
reset = 1'b0;
address = 11'h0;
write_enable_n = 1'h1;
read_enable_n = 1'h1;
chip_select_n = 1'h0;
# 100;
data_set = 8'h55;
write_enable_n = 1'h0;# 100;
data_set = 8'hzz;# 100;
read_enable_n = 1'h0;
# 100;
end
    module ht6116_tb();
    reg  data_set;
    reg  read_data;    // Somewhere to store the data in your test bench
    wire  data;
    reg  address;
    initial
    begin
    reset = 1'b0;
    address = 11'h0;
    read_data = 8'h00;     // You might want to provision your reg but you don't have to.
    # 100;
    data_set = 8'h55;
    # 100;
    data_set = 8'hzz;
    # 100;
    # 50;
    read_data = data;      // Read the data in (e.g. half way through your read enable pulse, but can be anywhere whilst read enable is active)
    # 50;
    # 100;
    end
    Cheers,
    Alex
    Well you could create a bidir controller. Search this forum for bidir (short for bidirectional) and you will find some references. You can also directly write Z when you read and write the value when you write.
