11 years agohow to read data from inout port into a testbench
Hi, I'm writing a test bench to write data into an sram module. I have to write the data and read back from it. data is inout port in that module. How do I read the data back from the module into my ...
10 years agoWell you could create a bidir controller. Search this forum for bidir (short for bidirectional) and you will find some references. You can also directly write Z when you read and write the value when you write.
