17 years agoHi All
Attatched is my Tcl script for checking a floating network license. You should manually edit the server ip address and port number in the file. Insert the following lines before your Tcl command to start Analysis&Synthesis and Assembler. source check_license.txt wait_for_license A00A_B00B This script will check the availability of the license feature again and again, until the feature is no longer occupied. So the compilation process wait for the license.
