8 years agohow to map many ports to a vector/array ?
Hi All,
I have an entiry with a lot of ports. I'd like to map these ports to a vector/array. example: Ports: bit_000_0 : in std_logic; bit_000_1 : in std_logic; bit_000_2 : in std_logic; bit_000_3 : in std_logic; bit_000_4 : in std_logic; Desired mapping of the ports to a vector: vec (0) <= bit_000_0; vec (1) <= bit_000_1; vec (2) <= bit_000_2; vec (3) <= bit_000_3; vec (4) <= bit_000_4; Can I use a function/package for this purpose? There are a lot of such ports (~150), so I'd like to do these assignments in the separate file (e.g. package) and do not clutter the top entity/module file. Is this possible? Thank you!3 Replies
Concatenation:
vec(4 downto 0) <= bit_000_4 & bit_000_3 & bit_000_2 & bit_000_1 & bit_000_0 - Altera_Forum
--- Quote Start --- Concatenation: vec(4 downto 0) <= bit_000_4 & bit_000_3 & bit_000_2 & bit_000_1 & bit_000_0 --- Quote End --- Could this assignment be done in the package? Remember that bit_000_4, bit_000_3, ... are ports - could they be observed from a package? - Altera_Forum
Because they are all single bits, then concatenation is about the only thing you can do.
