14 years agoI am afraid you are on the wrong path. you don't generate a clock like that. Normally you avoid generating clock from logic gating as you get all sorts of problems.
You are supposed to use the enable as enable not as clock. i.e. don't connect it to clock port of registers. Then you don't need to worry about timing as it will be synchronised with clk that generates it from the counter.
