12 years ago
How to make delay between states in VHDL state machine?
I'm trying to make a specified time delay (in seconds) between states. As in: start at state0, wait 3 seconds, move to state1 wait 10, seconds, move to state 2. However there is an input, such that if the input =1 then the time must be reset. So far i though of this:
Basically i made a counter to increment every second (from 24Mhz clock), and then used a binary signal to represent if the time is even or odd. I did this so that in each state i can test if a second has transpired and then increment the internal state clock. Once the internal clock reaches a value, I reset it and then transition to the next state. a to h represent LEDs, L and R are push down buttons on my DE1, FPGA. Ultimately I am just trying to learn how to make a state remain in itself until a certain amount of time has transpired. When I use this code, it doesnt function as i want it to, but im not sure why.
library ieee;
use ieee.std_logic_1164.all;
entity prop is
port ( L, R, CLK : in std_logic;
a, b, c, d, e, f, g, h : out std_logic );
end prop;
architecture behaviour of prop is
type state is (stopr, runl, stopl);
signal current_s, next_s : state;
signal counter : integer range 0 to 24000001 := 0;
signal sys_clock : integer range 0 to 36288000 := 0;
signal sub_clock : integer range 0 to 36288000 := 0;
signal clkevent : std_logic := '0';
signal check : std_logic := '0';
begin
state_register: process (CLK)
begin
if (rising_edge(CLK)) then
counter <= counter + 1;
if (counter = 24000000) then
counter <= 0;
sys_clock <= sys_clock + 1;
end if;
if (sys_clock mod 2 = 0) then
clkevent <= '0';
else clkevent <= '1';
end if;
current_s <= next_s;
end if;
end process state_register;
next_state_logic: process (current_s, L, R)
begin
case current_s is
when stopr =>
if (L = '1' OR R = '1') then
next_s <= stopr;
sub_clock <= 0;
elsif (check = NOT(clkevent))then
sub_clock <= sub_clock + 1;
check <= clkevent;
if (sub_clock = 3) then
next_s <= runl;
sub_clock <= 0;
else
next_s <= stopr;
end if;
else
next_s <= stopr;
end if;
when runl =>
next_s <= stopr;
sub_clock <= 0;
check <= clkevent;
if (sub_clock = 11) then
sub_clock <= 0;
next_s <= stopl;
else
next_s <= runl;
end if;
else
next_s <= runl;
end if;
when stopl =>
if (R = '1') then
next_s <= stopr;
else
next_s <= stopl;
end if;
when others =>
next_s <= stopr;
end case;
end process next_state_logic;
output_logic: process (current_s)
begin
case current_s is
when stopr =>
a <= '1'; b <= '0'; c <= '0'; d <= '0';
e <= '0'; f <= '0'; g <= '0'; h <= '0';
when stopl =>
a <= '0'; b <= '0'; c <= '0'; d <= '0';
e <= '0'; f <= '0'; g <= '0'; h <= '1';
when runl =>
a <= '0'; b <= '1'; c <= '0'; d <= '0';
e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if;
if (sub_clock = 4) then
a <= '0'; b <= '0'; c <= '1'; d <= '0';
e <= '0'; f <= '0'; g <= '0'; h <= '0';end if;
if (sub_clock = 5) then
a <= '0'; b <= '0'; c <= '0'; d <= '1';
if (sub_clock = 6) then
e <= '1'; f <= '0'; g <= '0'; h <= '0';end if;
if (sub_clock = 7) then
e <= '0'; f <= '1'; g <= '0'; h <= '0';end if;
if (sub_clock = 8) then
e <= '0'; f <= '0'; g <= '1'; h <= '0';end if;
if (sub_clock = 9) then
end if;
when others =>
end case;
end process output_logic;
end behaviour;
    I suggest using a clock for all of your code. Im guessing you're getting warnings about latches?
    There are several problems with the code.
    Your sub_clock counter wont work as you think it will because its not in a synchronous process. With your process, it will try and add 1 in a logic loop.
    You are missing signals in the sensitivity list for the next state logic. Without the correct list, simulation will not behave like the real hardware (you're missing sub_clock, check, clkevent
    Okay, so I tried to Fix it by taking a slightly different approach, but it still doeesnt behave the way it should. I'm still very new to VHDL so theres probably some fundamental concept that I'm not understanding.
    ----------------- CLOCK_start -------------------
    library ieee;
    entity Sys_clk is
    port
    ( CLK : in std_logic;
    Freq : out std_logic
    end Sys_clk;
    architecture Clock_behave of Sys_clk is
    signal osc : std_logic := '0';
    begin
    S_reg: process(CLK)
    begin
    if (rising_edge(CLK))then
    if (counter = 3000000)then
    if (osc = '0') then
    osc <= '1';
    else
    osc <= '0';
    end if;
    counter <= 0;
    end if;
    Freq <= osc;
    end if;
    end process s_reg;
    end Clock_behave;
    ----------------- CLOCK_end -------------------
    -------------- Ping Pong_start -------------------
    library ieee;
    entity Ping_Pong is
    port(
    Start, Lb, Rb, CLK : in std_logic;
    a,b,c,d,e,f,g,h : out std_logic
    end Ping_Pong;
    architecture Pong_Behave of Ping_Pong is
    type state is (wait_s, stopr_s, stopl_s, runr_s, runl_s);
    signal pres_s, next_s : state;
    signal count : integer range 0 to 10000000 :=0;
    begin
    State_Logic: process(CLK, start, Lb, Rb )
    begin
    if(start = '0') then
    pres_s <= wait_s;
    elsif(rising_edge(CLK)) then
    count <= count +1;
    case pres_s is
    when wait_s =>
    next_s <= stopr_s;
    count <= 0;
    when stopr_s =>
    if (Lb = '1' OR Rb = '1')then
    next_s <= stopr_s;
    count <= 0;
    else
    if (count = 12)then
    next_s <= runl_s;
    count <= 0;
    else
    next_s <= stopr_s;
    end if;
    end if;
    when runl_s =>
    next_s <= stopr_s;
    count <= 0;
    else
    if (count = 72)then
    next_s <= stopl_s;
    count <= 0;
    else
    next_s <= runl_s;
    end if;
    end if;
    when stopl_s =>
    if (Rb = '1')then
    next_s <= stopr_s;
    count <= 0;
    elsif (Lb = '1')then
    next_s <= stopl_s;
    count <= 0;
    else
    if (count = 12)then
    next_s <= runr_s;
    count <= 0;
    else
    next_s <= stopl_s;
    end if;
    end if;
    when runr_s =>
    next_s <= stopr_s;
    count <= 0;
    else
    if (count = 72)then
    next_s <= stopr_s;
    count <= 0;
    else
    next_s <= runr_s;
    end if;
    end if;
    when others =>
    next_s <= wait_s;
    end case;
    pres_s <= next_s;
    end if;--start = 0
    end process State_Logic;
    output_logic: process (pres_s,count)
    begin
    case pres_s is
    when wait_s =>
    when stopr_s =>
    when runl_s =>
    if (count = 0) then
    end if;
    if (count = 12) then
    end if;
    if (count = 24) then
    end if;
    if (count = 36) then
    end if;
    if (count = 48) then
    end if;
    if (count = 60) then
    end if;
    if (count = 72) then
    end if;
    when stopl_s =>
    when runr_s =>
    if (count = 0) then
    h <= '0'; g <= '1'; f <= '0'; e <= '0';
    d <= '0'; c <= '0'; b <= '0'; a <= '0';
    end if;
    h <= '0'; g <= '0'; f <= '1'; e <= '0';
    end if;
    h <= '0'; g <= '0'; f <= '0'; e <= '1';
    end if;
    h <= '0'; g <= '0'; f <= '0'; e <= '0';
    d <= '1'; c <= '0'; b <= '0'; a <= '0';
    end if;
    d <= '0'; c <= '1'; b <= '0'; a <= '0';
    end if;
    d <= '0'; c <= '0'; b <= '1'; a <= '0';
    end if;
    d <= '0'; c <= '0'; b <= '0'; a <= '1';
    end if;
    when others =>
    end case;
    end Pong_Behave;
    -------------- Ping Pong_end -------------------
