12 years agoOkay, so I tried to Fix it by taking a slightly different approach, but it still doeesnt behave the way it should. I'm still very new to VHDL so theres probably some fundamental concept that I'm not understanding.
----------------- CLOCK_start ------------------- library ieee; use ieee.std_logic_1164.all; entity Sys_clk is port ( CLK : in std_logic; Freq : out std_logic ); end Sys_clk; architecture Clock_behave of Sys_clk is signal counter : integer range 0 to 24000001 := 0; signal osc : std_logic := '0'; begin S_reg: process(CLK) begin if (rising_edge(CLK))then counter <= counter + 1; if (counter = 3000000)then if (osc = '0') then osc <= '1'; else osc <= '0'; end if; counter <= 0; end if; Freq <= osc; end if; end process s_reg; end Clock_behave; ----------------- CLOCK_end ------------------- -------------- Ping Pong_start ------------------- library ieee; use ieee.std_logic_1164.all; entity Ping_Pong is port( Start, Lb, Rb, CLK : in std_logic; a,b,c,d,e,f,g,h : out std_logic ); end Ping_Pong; architecture Pong_Behave of Ping_Pong is type state is (wait_s, stopr_s, stopl_s, runr_s, runl_s); signal pres_s, next_s : state; signal count : integer range 0 to 10000000 :=0; begin State_Logic: process(CLK, start, Lb, Rb ) begin if(start = '0') then pres_s <= wait_s; elsif(rising_edge(CLK)) then count <= count +1; case pres_s is when wait_s => next_s <= stopr_s; count <= 0; when stopr_s => if (Lb = '1' OR Rb = '1')then next_s <= stopr_s; count <= 0; else if (count = 12)then next_s <= runl_s; count <= 0; else next_s <= stopr_s; end if; end if; when runl_s => if (Lb = '1' OR Rb = '1')then next_s <= stopr_s; count <= 0; else if (count = 72)then next_s <= stopl_s; count <= 0; else next_s <= runl_s; end if; end if; when stopl_s => if (Rb = '1')then next_s <= stopr_s; count <= 0; elsif (Lb = '1')then next_s <= stopl_s; count <= 0; else if (count = 12)then next_s <= runr_s; count <= 0; else next_s <= stopl_s; end if; end if; when runr_s => if (Lb = '1' OR Rb = '1')then next_s <= stopr_s; count <= 0; else if (count = 72)then next_s <= stopr_s; count <= 0; else next_s <= runr_s; end if; end if; when others => next_s <= wait_s; end case; pres_s <= next_s; end if;--start = 0 end process State_Logic; output_logic: process (pres_s,count) begin case pres_s is when wait_s => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; when stopr_s => a <= '1'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; when runl_s => if (count = 0) then a <= '0'; b <= '1'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 12) then a <= '0'; b <= '0'; c <= '1'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 24) then a <= '0'; b <= '0'; c <= '0'; d <= '1'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 36) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '1'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 48) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '1'; g <= '0'; h <= '0'; end if; if (count = 60) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '1'; h <= '0'; end if; if (count = 72) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '1'; end if; when stopl_s => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '1'; when runr_s => if (count = 0) then h <= '0'; g <= '1'; f <= '0'; e <= '0'; d <= '0'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 12) then h <= '0'; g <= '0'; f <= '1'; e <= '0'; d <= '0'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 24) then h <= '0'; g <= '0'; f <= '0'; e <= '1'; d <= '0'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 36) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '1'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 48) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '0'; c <= '1'; b <= '0'; a <= '0'; end if; if (count = 60) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '0'; c <= '0'; b <= '1'; a <= '0'; end if; if (count = 72) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '0'; c <= '0'; b <= '0'; a <= '1'; end if; when others => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end case; end process output_logic; -- end Pong_Behave; -------------- Ping Pong_end -------------------
