15 years agoI assumed the same myself after reading the IP documentation. (Page-35 of floating point megafunctions userguide gives the detail for floating exponential IP). But after instantiating the IP and running testbench on the code, I found that initially it takes 17 clock cycles to produce the output and thereafter it takes only 6 clock cycles. Try it. Just instantiate the IP and run a testbench which constantly supplies input data. Let me know what you find.
