15 years agoThe "parallel" valid bit chain is simply a shift register (respectively a number of cascaded D-FFs), the delay (number of stages) is equal to the pipeline delay of the respective IP block.
I aggree, that Altera could have added it as an option, but as mentioned above, it won't be of any use in the standard application, where a continous data stream is fed to the IP.
