14 years agoI just installed Quartus II 11.1sp1 Web Edition under Ubuntu 11.10, and it generated a couple of errors related to this thread. Since the original poster did not post his solution to the pixmap issue, I'll post it here.
The first issue is the default locale. For some reason perl does not pick it up correctly, Qsys generates the messages
Info: Starting classic module elaboration.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "en_US",
LANG = "C"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
so you have to issue the command
sudo locale-gen en_US
and reboot (I'm not sure if the reboot is required, that was just the advice given on the web). For the pixmap error, Qsys generates messages like
(java:2050): Gtk-WARNING **: Unable to locate theme engine in module_path: "pixmap",
is fixed with
sudo apt-get install gtk2-engines-pixbuf
Cheers, Dave
