14 years ago --- Quote Start --- An interesting thread but what got lost in the discussion about USB was Kapare's comment at one spot about no Internet access from within Quartus. I was wondering whether you had resolved that problem. I am a Mac person and a complete novice at Linux, but got Quartus installed in Ubuntu using VirtualBox and so far this is the only problem I have had. (USB seems alright.) Firefox simply won't open even though the directory in the Quartus options is correct (checked with command line entry, albeit interestingly enough, with a couple of errors as Firefox opens.) Any advice you could give would be appreciated. Thanks! --- Quote End --- That error have only been seen during the installation and didn't cause problem on my internet connection in the virtual machine. My advise is that you should check your virtual machine settings to be sure Ethernet settings a properly set. You would found this information on Google and Virtual Box documentations.
