12 years agoAttached is my UDEV rules for Ubuntu 12.04. I know I had to modify them due to a change in UDEV system from 10.04 to 12.04, I've also added more variations, due to different dev kit versions of the USB blaster.
Let me know if these work for you. The number in the name: 53 vs 51 is just an ordering item, you can rename it as you wish. Remove the .txt extension. and copy into /etc/udev/rules.d Let me know if this helps. Pete
