12 years agoHi Franz,
I got exact problem you met. However, even I try your solution, but I still can not make usb-blaster working on Ubuntu 12.04 64bit. Do you have any idea what is going on? --- Quote Start --- hello all!!! someone can make usbblaster run on ubuntu 11.10???? i did 1 add on /etc/rc.localmount --bind /dev/bus /proc/bus
ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices 2 add on /etc/udev/rules.d/51-usbblaster.rules SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c" and when i did lsusb i see Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 413c:3012 Dell Computer Corp. Optical Wheel Mouse
Bus 005 Device 003: ID 413c:2106 Dell Computer Corp. Dell QuietKey Keyboard
Bus 007 Device 004: ID 09fb:6001 Altera -> here but when i do jtagconfig No JTAG hardware available
any ideia??? someone can help me ??? thanks Franz Wagner --- Quote End ---
