Altera_ForumHonored Contributor14 years agoHow to input a ext. clock in Stratix IV device? I need to input a video data and a clock from external.This clock will be used as a global clock. but there isn't dedicated clock input IO between FPGA and daughter card. Can I just use common data i...Show More
Altera_ForumHonored Contributor14 years agohi Rbugalho, thanks for reply. Do you mean that the schematic is not a good design?
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
