How to inject a crc_error into CycloneIV device
- 1 year ago
Unlike Cyclone V, Cyclone IV does not support in-system CRC error injection and recovery via nCONFIG pin alone. When CRC error occurs-Cyclone IV will enter configuration failure state.
Recovery from this state will require full reconfiguration cycle.
If CRC error remains high- consider to power cycle your board.
regards,
Farabi
Hello!
No, you can't inject a CRC error into a Cyclone IV device and then simply reload it using the nconfig pin as you would with a Cyclone V. The Cyclone V is designed with advanced, in-system self-correction features that support this, while the Cyclone IV is not. For a Cyclone IV device, a CRC error places it in a configuration failure state, which requires a full reconfiguration cycle to recover from. The nconfig pin will only trigger the device to re-enter the configuration state, requiring you to then reload the entire .sof or .rbf file to get it working again. The delay you're seeing is the device preparing for that full reload.
Thanks a lot!
