18 years agoHi,
--- Quote Start --- Going from 32 bits to 64 bits will be slower as the instructions are longer. --- Quote End --- This is only sort of true. If you run 64-bit Quartus on a 64-bit OS (say, Windows), you will see a small increase in compile time (on the order of 10%). This is mostly due to the increase in the working set (active memory) of the program due to the increase in size of pointers from 32-bits to 64-bits. However, if you run 32-bit Quartus on 64-bit OS, you will see no slow down at all. The advantage of doing this is (a) you get access to 4 GB of memory (up from 2GB in 32-bit Windows and ~3.5GB in 32-bit Linux), and (b) 32-bit Quartus will use less memory than 64-bit Quartus. Unless you are compiling a full design into the largest Stratix III device with complex timing constraints, you should be fine with a 64-bit OS + 32-bit Quartus. Regards, Paul Leventis Altera Corp.
