PrivateerEarl
3 years agoHow to globally enable weak pull ups on unused IO through Quartus Prime Pro (22.3)
I'm trying to figure out an easy way to enable weak pull ups on the unused IO pins of a Cyclone 10 GX device. Apparently there was an easy single option to select in the past (when we were implementi...
AqidAyman_Altera
3 years agoHi,
Do you need any more support on this issue?
Have you managed to get it solved by following the suggestion above?
