14 years agoHow to give sdc constraint between CPU and IP.
Hi All,
I have designed one memory controller. I have used one PLL to generate clock frequency for my memory controller.When I compiled the system, I got almost 1000 paths between CPU and Memroy Controller which are violating set up or hold timings.I want to give false path between all the NIOS II signals to memory controller signals.I can't use set clock groups because PLL input clock and CPU clocks are the same. Thanks in advance, Regards, Krupesh.
