14 years agoI suggest you to give an exception constraint between two different time domains: you may give
set_clock_groups -asynchronous -group {clk_A} -group {clk_B} ---or--- set_false_path -from clk_A -to clk_B set_false_path -to clk_A -from clk_B where clk_A and clk_B have been declared with create_clock or cretate_generated_clock or derive_pll_clocks (depending on your design). You ought to check your design contains proper synchronization among time domains. Regards, Gabriele
