How to get state machine encoding type from TCL ::report or where?
I have enumerated reports and find them in the report panel. For a particular state machine, it says 'Encoding Type: One-Hot'. When I use get_report_panel_row, it has all the table states, but I don't know what the API is to get the 'Encoding Type'? It seems like it is report meta-data of some sort?
set panel_names [get_report_panel_names]
foreach panel_name $panel_names {
## Do match state machine.
if {[string match "Analysis & Synthesis||State Machines||State Machine - |*|state" $panel_name]} {
set num_rows [get_number_of_rows -name $panel_name]
for { set i 0 } { $i < $num_rows } { incr i } {
set row_data [get_report_panel_row -name $panel_name -row $i]
post_message [join $row_data ","]
I really want to test the 'Encoding Type' of the state machine to verify "One-hot".
The code above dumps the state machine transitions.
- TingJiangT_Intel
Contributor
I don't fully understand what you’d like to do.
If you want to get the Encoding Style information you can open quartus -> compilation report -> Synthesis -> Partition "root_partition" -> State machine
And you can right click the report you want like the state machine summary and click 'export' to generate the report.
- BillP_
Yes, I can see it. I understand how to use the GUI.
I want to use TCL and a post synthesis script to check that all state machines are one-hot.
Ie, I want a script to be able to access "Encoding type"
I want an answer without 'click'. Is that possible?
- TingJiangT_Intel
Contributor
Hi there, can you upload the tcl file you currently use. Seems some error with the command copied from your previous post.
- TingJiangT_Intel
Contributor
