12 years ago
How to get quartus_sta to return and error code if timing not met
I have not been able to find this on the forums or with google.
I use a makefile to run quartus. My problem is that I can generate timing reports with quartus_sta, but I would like quartus_sta to return an error code (non-zero) if timing constraints were not met. Right now there is no notification of a failed design, ie quartus_sta always returns 0.
I would prefer to not have to generate a project.sta.rpt and then grep for failures.
1 Reply
    Great question! I want to get this information as well.
    Unfortunately, my Makefile builds the project using:
    $(QUARTUS_BIN)/quartus_sh --tcl_eval load_package flow \; project_open $* \; execute_flow -compile
    ... which is needed to get preflow scripts to run properly. So I guess getting the build status will be even harder for me.
