How to get QSYS to propagate SYSTEM_INFO GENERATION_ID value into composed component
Sure.
If you build this simple design you will find a top RTl with a QSYS in it.
Within the QSYS is a simple design of an I2C to Avalon-MM master attached to:
1. A SYSID component directly with ID=1
2. A QSYS Subsystem with a SYSID embedded in it with ID=2
3. A Composed QSYS component with a SYSID embedded in it with ID=3
Looking into the generated SYSID instances (source generated by QSYS) it is very easy to see that:
(1) has a timestamp properly generated: assign readdata = address ? 1646427247 : 1;
(2) has a timestamp properly generated: assign readdata = address ? 1646427247 : 2;
(3) does not have the GENERATION_ID (timestamp) flowing to the instance: assign readdata = address ? 0 : 3;
So basically, this does not work when a component is composed instead of included in a system or subsystem directly (this is taken from altera_avalon_sysid_qsys_hw.tcl).
# | parameters
add_parameter timestamp INTEGER 0
set_parameter_property timestamp DEFAULT_VALUE 0
set_parameter_property timestamp DISPLAY_NAME "Time stamp"
set_parameter_property timestamp TYPE INTEGER
set_parameter_property timestamp UNITS None
set_parameter_property timestamp AFFECTS_GENERATION true
set_parameter_property timestamp HDL_PARAMETER false
set_parameter_property timestamp SYSTEM_INFO GENERATION_ID
set_parameter_property timestamp ENABLED false
set_parameter_property timestamp VISIBLE false
set_parameter_property timestamp DERIVED true
The HW.TCL for the "composed" component is this:
# _hw.tcl file for composed
package require -exact qsys 14.0
# module properties
set_module_property NAME {composed}
set_module_property DISPLAY_NAME {Composed sysid}
# default module properties
set_module_property VERSION {1.0}
set_module_property GROUP {dcattley}
set_module_property DESCRIPTION {Composed component with sysid embedded}
set_module_property AUTHOR {[email protected]}
set_module_property COMPOSITION_CALLBACK compose
set_module_property opaque_address_map false
# | parameters
add_parameter id INTEGER 0
set_parameter_property id DEFAULT_VALUE 0
set_parameter_property id DISPLAY_NAME "32 bit System ID"
set_parameter_property id TYPE INTEGER
set_parameter_property id UNITS None
set_parameter_property id AFFECTS_GENERATION true
set_parameter_property id HDL_PARAMETER false
# | display items
add_display_item "" id PARAMETER
set_display_item_property id DISPLAY_HINT hexadecimal
add_display_item "Description" id text "Please use hexadecimal numbers only in System ID."
proc compose { } {
# Collect parameter values into local variables
foreach var [ get_parameters ] {
set $var [ get_parameter_value $var ]
send_message info "composed:id = $id"
# Instances and instance parameters
# (disabled instances are intentionally culled)
add_instance clk clock_source 18.1
set_instance_parameter_value clk {clockFrequency} {50000000.0}
set_instance_parameter_value clk {clockFrequencyKnown} {0}
set_instance_parameter_value clk {resetSynchronousEdges} {NONE}
add_instance csr altera_avalon_mm_bridge 18.1
set_instance_parameter_value csr {ADDRESS_UNITS} {SYMBOLS}
set_instance_parameter_value csr {ADDRESS_WIDTH} {10}
set_instance_parameter_value csr {DATA_WIDTH} {32}
set_instance_parameter_value csr {LINEWRAPBURSTS} {0}
set_instance_parameter_value csr {MAX_BURST_SIZE} {1}
set_instance_parameter_value csr {MAX_PENDING_RESPONSES} {4}
set_instance_parameter_value csr {PIPELINE_COMMAND} {1}
set_instance_parameter_value csr {PIPELINE_RESPONSE} {1}
set_instance_parameter_value csr {SYMBOL_WIDTH} {8}
set_instance_parameter_value csr {USE_AUTO_ADDRESS_WIDTH} {1}
set_instance_parameter_value csr {USE_RESPONSE} {0}
add_instance sysid altera_avalon_sysid_qsys 18.1
set_instance_parameter_value sysid {id} $id
# connections and connection parameters
add_connection clk.clk csr.clk clock
add_connection clk.clk sysid.clk clock
add_connection clk.clk_reset csr.reset reset
add_connection clk.clk_reset sysid.reset reset
add_connection csr.m0 sysid.control_slave avalon
set_connection_parameter_value csr.m0/sysid.control_slave arbitrationPriority {1}
set_connection_parameter_value csr.m0/sysid.control_slave baseAddress {0x0000}
set_connection_parameter_value csr.m0/sysid.control_slave defaultConnection {0}
# exported interfaces
add_interface clk clock sink
set_interface_property clk EXPORT_OF clk.clk_in
add_interface csr avalon slave
set_interface_property csr EXPORT_OF csr.s0
add_interface reset reset sink
set_interface_property reset EXPORT_OF clk.clk_in_reset
# interconnect requirements
set_interconnect_requirement {$system} {qsys_mm.clockCrossingAdapter} {HANDSHAKE}
set_interconnect_requirement {$system} {qsys_mm.enableEccProtection} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.insertDefaultSlave} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.maxAdditionalLatency} {1}
## --end-- ##
regards,
Dave Cattley
