13 years agoTrue, but you'll have to work that out for yourself. Afaik, the synthesisor cannot work out the 2^n constants itself. The example would also fall down and get complicated as the constant values get larger and larger. Your example is very simple and just requires a single adder. As the constants get to values requiring 10s or 100s of adders, a DSP block might be easier.
