13 years ago --- Quote Start --- I dont quite get what the problem is? DSP blocks are the fastest way to do multiplies on the chip. So why would you not want to use them. --- Quote End --- That's true if both inputs are variables. However, when one side is a constant using the multiplier is probably the slowest. For example, 30*X would be DRAMATICALLY faster being done as 32*X - 2*X. A multiplier can't even get close.
