12 years agoHow to force Qsys library component to use registers for SCFIFO
I am trying to implement a Qsys design but I am running out of M9K RAMS, the design uses 2 more M9K than those available in the FPGA. The design uses 2x sgdma. I looked at the RAM resource use and the sgdma has a command FIFO of 45 x 2 bits. This uses 2 x M9K and is implemented with a SCFIFO. I would like to force these instances of SCFIFO to use registers instead of M9K since I have plenty of spare regs. I should be able to set the parameter "use_eab" to "OFF". I am new to Qsys and can not find out how or where to set this parameter for these particular instances of SCFIFO. I believe it would be easy to set the parameter if the SCFIFO was instantiated as a Mega Function but that sort of defeats the purpose of Qsys. Any help would be much appreciated. Thanks Mike
