SSchw11
6 years agoHow to find the parameter check box called "Provide separate interface for each channel" in the "Transceiver Native PHY Intel Arria 10" IP core?
I am using Quartus Pro 19.3 and the "Transceiver Native PHY Intel Arria 10" IP core. According to the documentation there should be a parameter check box called "Provide separate interface for each c...
Deshi_Intel
6 years agoHi,
I am using Red Hat and I am able to see the checkbox.
You can try regenerate your NativePHY IP again or create a new Quartus Project again to see if it helps.
dlim
