SSchw11
6 years agoHow to find the parameter check box called "Provide separate interface for each channel" in the "Transceiver Native PHY Intel Arria 10" IP core?
I am using Quartus Pro 19.3 and the "Transceiver Native PHY Intel Arria 10" IP core. According to the documentation there should be a parameter check box called "Provide separate interface for each c...
Deshi_Intel
6 years agoHI,
Steve has a point.
once you set the transceiver channel number > 1, then the "provide separate interface for each channel" option will pop up under "Datapath Options" section where user typically configure the data rate.
dlim
