SSchw11
6 years agoHow to find the parameter check box called "Provide separate interface for each channel" in the "Transceiver Native PHY Intel Arria 10" IP core?
I am using Quartus Pro 19.3 and the "Transceiver Native PHY Intel Arria 10" IP core. According to the documentation there should be a parameter check box called "Provide separate interface for each c...
sstrell
6 years agoJust to make sure, have you set the number of channels to a value greater than 1?
#iwork4intel
