How to fill Platform designer documentation
- 6 years ago
Hi Josef,
The enhancement is for our engineering. Currently, they are no parameter that you can use for hw.tcl or setting files for this generation.
Just to be in sync, Platform designer create a HTML files.
It would be on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_intro.pdf 6-24.
If you were looking into different HTML files, can you attached an example for us to look into this? As we usually do not use HTML file to modify the IP. The best way is still use the _hw.tcl files
- JoEl6 years ago
Hi Kenny,
OK I took it as bundle of software but you are right, I meant platform designer generated files.
I am aware that I cannot share structure described in top html files cause our policy, but we are talking about same thing.
My goal isn't editing IP within HTML, but use it as generated documentation of projject, so I would be able to give it to my colleague as an example of architecture or to sw team as description of inside structure/registers etc...
Iam looking for description how to pass those parameters to this file. IE component itself is well structured, you can find even few comments in its description but in top level qsys file there is much less informations, see pic below
not only missing parameters but also others can be passed to top level file, you already generate this so how can I pass more inside ?
