18 years agoSelect the bus and type a name for the bus like: result[8..0]
Then, using the Orthogonal Node tool, create a line, select the line (signal) and type a name for the signal like: result[5]. This signal is the bit 5 of the bus result[8..0]. (Sorry for the bad english, i'm brazilian):) Rodrigo Willians
