For NIOS, and I presume the same will be true for SoC stuff, I just exported the IRQ input just like any other conduit. Then connected all senders to it in the next block up.
If you want to export it completely from Qsys, you can use an "IRQ Bridge" (in "Basic Functions\Bridges\Interrupt\" or something like that) which allows you to select the width of your conduit (how many interrupts), and then gives you an appropriate number of IRQ lines which you can connect and number in Qsys. - Altera_Forum
Thank you for the answer, but I think that you mean different kind of export
I don't want to export actual wires and use it out of Qsys, I want to export from Qsys where are these wires connected. Eg. If I have component A and irq lane 0 and have irq 2, 3, 4 connected there I need to output some file which will have something like this: irq0,2 -> A,irq0 irq0,3 -> A,irq1 irq0,4 -> A,irq2 I need to automatize this export so that when I change system in Qsys I will get file which I will parse to C header, DTS or whatever to get mapping into driver so that driver will know exectly where to expect interrupts from which device...
