How to do perform simulation in the Intel Quartus prime Pro using Questasim
How do I perform simulation for any design using Questasim in the Quartus Prime pro. cuurently I am using Quartus Prime Pro 24.1 version.
1. there is no Run RTL simulation option in the tool menu like in the lite or prime.
2. if I have to do using .tcl and .do file, then how do I get this file and what will be the further process.
I am using Quartus software first time.
- RichardT_altera
You may checkout this user guide for how to simulate using Questa*-Intel® FPGA Edition, with the example design provided in the document.
https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/quick-start.html
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- Amit4
Hi Richard,
Thank you for your reply. The issue is resolved now.
However, I have different problems related to implementing the jesd204 design example and doing FPGA implementation. I have generated the design example; for FPGA implementation, I am using Altera Apollo SOM board and AFE79xx EVM; I need help with the pin assignment, like how to check which pins to give for refclk_core and refclk_xcvr and mgmt_clk, etc.
Can you please help me with this?
Thank you
- RichardT_altera
I'm pleased to hear that your question has been addressed.
At Altera, we recommend opening a new case for each unique technical issue. This helps with case analysis and allows us to better assess your support needs.
I noticed you've submitted a follow-up question in a new case, and an agent will be assigned to it shortly.
You can follow your case here:
Pin Assignment for JESD204B using Apollo Agilex 7 and AFE79 EVM
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
