18 years agoHello David,
I don't think it's a stupid question. I wonder, why most VHDL guides never touch it. Personally, I have often used a construct like thisUSE ieee.math_real.log2;
USE ieee.math_real.ceil;
CONSTANT NBIT : INTEGER := INTEGER(CEIL(LOG2(REAL(MAXCOUNT-1))); Alternatively, you can use an integer log2 function, like this function log2(A: integer) return integer is
begin
for I in 1 to 30 loop -- Works for up to 32 bit integers
if(2**I > A) then return(I-1); end if;
end loop;
return(30);
end; If the bitcount constant shall be used in the entities generic part, it must be supplied by another module or a package preceeding the entity definition. If it is needed in the architecture declaration only, all calculations can be done here. Best regards and Happy New Year! Frank
