JGome70
6 years agoHow to debug Internal compiler error of I++
I am experimenting with Quartus 19.4. I have a component to create IP using the HLS compiler. I followed a Makefile structure very similar to what is found in the counter example. While that example ...
- 6 years ago
Upon checking, the HLS does not allow you to compile class methods as functions into RTL unless they are declared ‘static’.
MEIYAN_L_Intel
6 years agoHi,
There is an mismatched parameter as stated:
"Internal Compiler Error: Number of parameters mismatched. This may be due to empty types are being optimized away"
I am checking the information internally with developer.
