How to debug Internal compiler error of I++
I am experimenting with Quartus 19.4. I have a component to create IP using the HLS compiler. I followed a Makefile structure very similar to what is found in the counter example. While that example seems to work fine, when doing make test-fpga I get the following output:
Target FPGA part name: 10CX220YF780I5G
Target FPGA family name: Cyclone10GX
Target FPGA speed grade: -5
Analyzing testbench_bilateral_filter_fixed.cpp for testbench generation
Creating x86-64 testbench
Analyzing testbench_bilateral_filter_fixed.cpp for hardware generation
Optimizing component(s) and generating Verilog files
Internal Compiler Error: Number of parameters mismatched. This may be due to empty types are being optimized away
HLS Main Optimizer FAILED.
Makefile:61: recipe for target 'test-fpga' failed
make: *** [test-fpga] Error 1How can I debug or find more information about the actual issue? I have reduced the code to a minimum and hardcoded many parts but cannot find a way around this issue.
UPDATE: I have reduced the code to a minimum to reproduce this issue. It seems the problem is when the component is a class member (code adapted from this video):
#include "stdlib.h"
#include "HLS/stdio.h"
#include "assert.h"
#include "HLS/hls.h"
class ProofOfComponent
public:
component int accelerate(int a, int b);
component int ProofOfComponent::accelerate(int a, int b)
return a+b;
int main(int argc, char** argv)
ProofOfComponent poc;
srand(0);
int x = rand()%10;
int y = rand()%10;
int z = poc.accelerate(x, y);
printf("%d + %d = %d\n", x, y, z);
assert(z == x + y);
return 0;
}Could somebody explain why this is not possible? It is standard C++.
Thank you in advance!
Upon checking, the HLS does not allow you to compile class methods as functions into RTL unless they are declared ‘static’.
- MEIYAN_L_Intel
There is an mismatched parameter as stated:
"Internal Compiler Error: Number of parameters mismatched. This may be due to empty types are being optimized away"
I am checking the information internally with developer.
- MEIYAN_L_Intel
