13 years agoWhat's the source file for your decoder? (HDL or schematic?)
If it's HDL then in verilog you would declare your input to be something like this "input [15:0] my_input_data;", and in VHDL it's something similar using a logic_vector (my VHDL is rusty so I'll leave that up to you to figure out). When you run the symbol generator on that you should end up bit a vectored input in the symbol. If you are using a schematic as the source then what I recommend doing is labeling a bus line to group all the individual signals together, then connect that bus line to a pin. It's probably easiest to label the input pin as "my_input_data[15:0]" in your schematic and then to use the individual bits you would draw individual bit lines that are labelled "my_input_data[0]", "my_input_data[1]", etc... in your logic. Quartus knows that when you use the subscripts with the same net name that they should be logically connected.
