13 years agoHi,
These are very basic things. I recommend you find a good VHDL book and learn the syntax. constant ff_tx_mod : IN STD_LOGIC_VECTOR (1 DOWNTO 0) := '00'; should be: constant ff_tx_mod : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00"; You use IN to define an input to an entity. variable gm_tx_d2 :STD_LOGIC_VECTOR (7 DOWNTO 0) := '00'; should be: variable gm_tx_d2 :STD_LOGIC_VECTOR (7 DOWNTO 0) := "00000000"; because your vector has eight elements. constant ff_tx_mod : IN STD_LOGIC_VECTOR (1 DOWNTO 0) := '00'; get rid of the IN since this is not an input to the entity. constant preamble : STD_LOGIC_VECTOR (7 DOWNTO 0) := '5555555555555555'; You define an eight bit vector and then try to stuff a huge number into it. The biggest unsigned number that can be represented by eight bits is 255. Mark.
