13 years agoHow to correct the error
LIBRARY ieee;
USE ieee.std_logic_1164.all; ENTITY CHAR_7SEG IS PORT ( c : IN STD_LOGIC_VECTOR(2 DOWNTO 0); HEX0 : OUT STD_LOGIC_VECTOR(0 TO 6)); END CHAR_7SEG; ARCHITECTURE behaviour4 OF CHAR_7SEG IS BEGIN case c is WHEN 000 => HEX0 <="76" ; WHEN 001 => HEX0 <= "79"; WHEN 010=> HEX0 <= "38"; WHEN 011=> HEX0 <= "38"; WHEN 100=> HEX0 <= "3F"; WHEN OTHERS => HEX0 <= "00"; END case; END behaviour4; THE ERROR SHOWING IS ---->> Error (10500): VHDL syntax error at CHAR_7SEG.vhd(22) near text "case"; expecting ";", or an identifier ("case" is a reserved keyword), or "architecture" . HOW TO CORRECT THIS ERROR??
