13 years agoInitially, it should sense or monitor voltage and current at the input of the drive and at the load as well. Is that possible to measure continuous value..???
As you said it has a Max. Voltage of 30V and Current of 15mA. Is that possible to operate it with the 50kHz clock frequency..? coz in the Alter circuit board we have clock signal of 50MHz. Regards, Navin R
