13 years agoHello Dave,
Thank you so much for your response, with respect to the Space vector modulation index "m" pulse should be given to the IGBT driver. for ex. 10ms in state s1 and next 10ms in and so on s2, s3, s4, s5, s6. By switching this way it will produce sine wave as output with the variable amplitude and frequency. In the voltage source inverter we have 6 states as mentioned above and two null states. Regards, Navin R
