17 years ago --- Quote Start --- maybe i will try this using DC, it supports gated clock constraint. --- Quote End --- For simple reasons already explained by others, if you can't specify a timing relation between a and b input, no tool will be able to perform a timing analysis. You have to exepect glitches at c. If c is only clocking a single FF as in your example, there are probably no consequences for your design, otherwise you should be cautious. As an additional remark: The problems brought on by such designs are typically more serious with rare timing violation events. You don't see them in a test, but the system reveals unreliable in operation at customer site.
