17 years ago --- Quote Start --- what are the properties of a and b? are they both masked clocks or one is clock and the other - masking signal? do you intend c to be edge aligned with a/b? --- Quote End --- a and b are both not clock, they are the signals changed between 0 and 1, the relationship between a and b are uncertain。 the FAQ of altera say i can use"generated clock"command to constraint the output of "and" gate,but i still didn't know how to do this.
