18 years agoWith the Classic Timing Analyzer, use "Cut Timing Path" between the clock domains using the form of the PLL output node names you see in the timing report. If you have paths going in both directions between clock domains, add a cut-path setting for each direction.
With TimeQuest, do something similar with set_false_path in each direction or use set_clock_groups. See the on-line help for these settings for more information.
