Altera_ForumHonored Contributor15 years agohow to constrain timing between FPGAs? Hi, I have two FPGAs which are each clocked by the same system clock. One FPGA provides a data signal to the other. I want to make sure I am meeting timing. If the source FPGA were a n...Show More
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
